I have a question about seat mounting. I have not yet run this car at Bonneville. The roll cage should meet the requirements OK. The seat, the lap belts, and the submarine belt are currently bolted to the floor and not to the cage. I want to correct that deficiency and mount the seat and all of the harness entirely to the cage but am in a quandry as to how to do it. There is not enough room between the door sill and the transmission/drive shaft tunnel to construct seat and belt supports out of 1 5/8" tube and still have enough room for the seat. Can I build a "basket" for the seat out of 1" tube and weld it to the cage, or will that then be considered part of the cage and made out of under-sized tubing? DickJ
