I have been researching the idea of running a Honda Insight with a number of different powertrains for a few months now (well, pretty much since the flight home from Speedweek
) and thought this information may be useful for others.
I got a response back from Jim Miller regarding my inquiry about putting a like-branded motorcycle engine in a car for the GT class.
I wanted to put a CBR1000RR engine in the Insight and run it under GT. This isn't legal, but not only for the reason I expected. Yes, it is not legal for the following reasons, which I pretty much anticipated:
My biggest (problem) is in paragraph 2 on page 74. it says ....as long as the original running gear design is retained... When you swap out the transaxle with electric motor hookup, half shafts etc you change the original design as the bike engine has a clutch inside it's case and is chain driven. Engine swaps are allowed from the same mfg. If you then go to pg 70, 5.E it says engine...as purchased from any AUTOMOBILE Dealer... If the engine in question was used in any Honda Automobile, no problem.
However, there is another problem with the Insight because it is a hybrid:
Our Impound man pointed out Pg 71 last paragraph. Another problem is if you swapped out a motor in a hybrid you would have to keep all the battery packs etc and the OEM throttle body.
Everyone queried on this change (Coupe and Sedan and Mod Sports/GT committee and Impound said the car has to run in Mod. Sports.
Perhaps this is why the Insight #2010 didn't run at this year's Speedweek? It was G/GT as I recall... under the above, that's not legal unless he put in a G engine but kept the hybrid running gear.
So, there you have it. My questions have all been answered (for now). As the rules are written right now and as I interpret the above:
-If you do an engine swap in an Insight, you cannot run it in GT unless you retain the hybrid running gear.
-You cannot run a motorcycle engine in a car in GT unless that motorcycle engine was available from a car dealer, but even then it might still not be legal because of the difference in the way the transaxle is connected.
