the seal is so that you cant change the cu. in. of the motor --if they seal the oil pan bolts (2 on each side) then you can pull the heads without breaking the seal in case of more port work or a blown head gasket --on the bikes they use a wire and a lead seal like on your electric meter ---------willie buchta
