Sumner is right, the number one thing to look out for is oil control. I f you dont have a dry sump or dont plan on getting one, what we have done in the past is add extra oil to the system.If you have a 7 qt. pan and you want to run to the 5 mi., add 2 to 3 extra qts. depending on engine rpm. I know it sounds like to mutch , but you will probly have 3 to 4 qts. in the top end by the 3 mi. mark if your running 7000 rpm or so.
