Ratliff the description on E-Bay says front wheel drive and single rear wheel arrangement, Why the hell do you have to argue and always think you a the only expert.
It's got two rear wheels mounted in a configuration that forms a trapezoid.
"Two separate 17" aluminum rims with 2.0 x 2.5 x 17 inch Goodyear racing tires mounted in "siamese" fashion directly next to each other on heavy duty bearing mounted axle (technically qualifying as a four wheeled entrant?). Suspended by four link type system with coilover shocks and with what appears to be a small air suspension diaphram at rear of frame for adjustment. Overall wheelbase is 146" inches, length of Streamliner is approximately 14' feet. As an historical note, this Streamliner was intended to be powered by a Charles "Kong" Jackson prepared flathead with the intake and exhaust ports reversed."
