Thanks for all the encouragement and ribbing. I'm finally confident that I'm heading in the right direction.
As was my suspicion, up until now, I simply had no place to find out when the engine came on the cam. It appears to up there a ways. Unfortunately, I didn't take particularly good notes, but I do need to launch it above 4500 or 5k to get it over the hump, and it will just stumble until the momentum of the air through the head starts to hit the sweet spot.
I've got two thoughts in mind to try to build up the lower end of the powerband. 1st off, I'm thinking of going with a slightly smaller set of venturis in the carb, in hopes that the flow rate will pick up a bit at a lower RPM. I don't think I've got any restriction of consequence on the intake side, and getting the intake speed up should be somewhat helpful.
Additionally, a longer manifold might help. I've seen some A-Series Weber manifolds as long as 7", and while that would be impractical in my application, I've got a 4" Maniflow manifold I can cut the flanges off of and have a manifold welded up that will maximize the available space.
What I did came away with, and what has re energized my efforts, is that indeed, the short stroke, way-too-big rod-to-stroke ratio does indeed work.
I need to get a bit of dyno time in. I want to get a
true baseline - something other than the seat of my pants.
A Confirm and maximize the timing
B See if I can utilize and/or maximize the knock sensor to my advantage, which I simply bypassed at Maxton
C Change out the venturis
That would be a solid day on the dyno - not cheap, but cheaper than a trip out west.
And I've GOT to get this thing aligned - it was like a water strider, skipping across a pond.
I'm glad you are home, Midget.
But it also felt good to participate, didn't it?
Freud, seriously, Wednesday night. after packing up, I looked at the Midget and the trailer, and almost talked myself into just spectating - that's how unsure I was. I came within a gnat's Acura of loading up the trunk of the MGB, and just calling it a vacation.
But once I was going through Rookie O, and had the car in line, I realised, and I think for the first time, that this is not spectator sport.
So yes, my friend, it felt REALLY good to participate, and more importantly, to do so at a level that I don't have to make any apologies for or jokes about.
Yeah, Glenn, it really, really did.
