I read back through the previous couple of pages and I am not sure so I will ask. Did you try setting the cam with the .050 lift opening and closing figures from the cam card?
Here's a copy of the cam card -
What I did was I averaged the degrees at .050
drop from either side of full lift, and right now, it's at 102.
This is turning into a great lesson on applied geometry and nonlinear arc correlation - oh, and reading the entire instructions.
I needed to build the lash into the measurement, and rereading the card, it occurred to me that I've got more lash available than I originally calculated. I don't know where I came up with my original .010 figure - probably my MGB - but with .018 lash and no gasket, my tightest clearance becomes .023. The balance of my clearance can be handled linearly by either going with a thicker gasket or machining the piston.
Chris try the Cometic MLS head gasket around .090 or so.
Charles
Doesn't look like I'd have to go that big, maybe about .070, but it raises the question as to what issues might arise with a headgasket that thick? I would be able to maintain a static CR in the upper 12's with that.
A huge plus would be that it would be a retrievable fix if it didn't work.
And thanks for the input, Charles, Buddy, Stan, Doc, Tom, P.J., Anvil*, Graham - it's ALL appreciated, trust me.
