Because I didn’t believe him when Chris said the bolts had 9mm threads, since 9mm is neither a preferred nor standard ISO metric thread, I went over to ARP and got a drawing of what they put in their K series kit. Son of a gun, they’re 9 mm.
Whereas the standard connector is a headed bolt, ARP is using a stud with washer and nut on the top. The stud is 16.6” OAL, with 1.03” of rolled threads on each end. The bottom thread is MJ9x1.25 and the top MJ9x1.0. The body is a uniform 0.333” (8.46mm) diameter. The 9mm washer is 0.812” OD and the M9x1.0 twelve point nut is 0.375” high with 0.615” OD flange. Stud material is their AISI 8740 steel which, per their catalog, has a yield strength of 180 ksi and ultimate of 200 ksi.
Put this all together with ARP’s stated 50 lb-ft make-up torque and an assumed 0.09 friction coefficient (which is reasonably realistic) and we produce a load of 11,900 pounds in the stud at 136,700 psi longitudinal stress, which is right at ARP’s recommended 75% of yield.
Before getting carried away with beefing up the oiling ladder it may be good to realize that it is really only a glorified nut plate which also feeds some oil to the bearings. It is the girdle’s job to rigidify things. The ladder is too narrow and too thin to add any inherent stiffness. Why do we think all this reinforcement is needed? More revs but shorter stroke--is it a problem? If it were more displacement and a turbo maybe it would be a concern. I’m with Fordboy--relax--until a potential problem is identified.
An interesting exercise might be to find a piece of aluminum of about the same hardness and thickness as the ladder, tap it to M8x1.25 or M10x1.25 (standard sizes), get a high grade bolt of that size with comparable engagement, crank it up and see what happens. Might show that there’s nothing to worry about.
While at ARP, I asked about the possibility of longer studs, thinking studs are a lot simpler than a headed fastener. As would be expected, they would want to quote to a given quantity, but for one or two sets, the impression I got was that it would be quite pricy.
The “flaw” in the ladder is most likely just a casting join-line where the material from each end came together, was somewhat cooled by the surface and was reluctant to meld completely. Light grinding would probably show it to be only a surface discontinuity.
