So there appears to be the possibility of using the ribcage transmission with the Kettle without having to relocate it.
midget,
Not so important, UNTIL, I inform you of the latest development:
Jim Fletcher, of Period Performance Developments in Gilberts, IL has graciously offered to loan you the use of a close ratio ribcase gearbox fitted with Hewland Mk VIII dog engagement gears. In return, the car will need to carry the PPD logo as a sponsor.
BENEFITS:1) We will be able to select ratios for progressive drops throughout the gears. Top will remain 1/1 I believe.
2) Retention of gearbox location and mounting.
3) Rpm range between peak torque and peak bhp can be engineered narrower.
4) We can "bump up" the peak bhp curve.
NEGATIVES:1) Only 4 speeds, not 5.
2) The fact that it is a 4 speed MAY (most likely . . ) require a higher speed push start. Say 50/60 mph. (?)
3) Well, he will want it back . . . . .
This is all, of course, subject to your final approval.
