Warning Will Robinson!! Warning!!Below are photos of a $5000.00 (approximately . . ) Swiftune cylinder head currently seeking employment as a . . . . . BOAT ANCHOR . . . . . preferably in the Royal Navy!!
Uhhmmm, don't let anyone tell you that sinking the valves into the chamber roof is
NO PROBLEM. On this late style "sculpted" 12G940 cylinder head, the valve depth combined with an overcut larger than what Swiftune originally machined into the chamber, has opened a "defect" into the water jacket . . . . . . . This particular valve is about .03"/.75mm deeper than the other valves. Combined with a .06"/1.52mm larger "overcut" this "valve job" found water.
BTW, the defect has been "picked at" just to see how extensive it might be. The "water" was discovered at speed, in competition, after a 400 mile tow . . . . . .
That particular valve is .021"
deeper than the chamber depth . . . . . (measurements taken with the head inverted) and you can see how heavy the "overcuts" were made.
If you are going to modify your head in this manner, you might consider ultrasound checking the thickness of the casting
FIRST. Or not . . . . .
Checkitfirstboy
