Had a great visit with Mr. and Mrs. Fordboy yesterday. Kate and I picked up a pile of roasted Mexican veggies and some tortillas, did a table top buffet and made gluttons of ourselves. Mark introduced me to a Mexican ale with a touch of chili pepper in it, and it had a very cool cedar finish to it. I liked it well enough that I can't remember the name . . .
And while the ladies chatted, we went to the offices of the illustrious Lake Villa air flow research and Brit-bit development center, aka, the basement, and compared flow bench charts with the actual heads he's been checking for me and other customers. Fascinating stuff.
There are subtle differences in BMC castings and head preparation techniques, the results of which have been posted earlier, leading to widely varying flow results.
The short side radius seems to be the key to the best flow - essentially trying to find the path which most gently and directly lets the air into and out of the chamber. It's not easy - vertical valves and side draft carbs mean 90 degree turns - it's about finding the line that lets the air in without tripping over itself too much, and making the radius as gentle as possible without cutting into the water jacket. One of the better flowing heads biased the flow in such a way that one might think would restrict flow, but that wasn't the case. In fact, despite smaller intake valves, it flowed better than my larger valve Longman head. The intake side ports from the manifold were also only minimally ported, demonstrating that the shape of the pocket is much more important than the size of the port.
We reviewed it all. The conclusion we came to earlier this week is that the head I chose is well suited to a one liter version of this engine, and the best possible improvement, short of having a new head cut from scratch, is to go with the Rimflow valves on the exhaust side of my head.
And they are on order.
About the only thing I need to know is how much extra displacement in the combustion chamber the Rimflow provides me, and if it's going to be a clearance issue.
I picked up the deck plate, so if I can get this thing apart, I can drop off the block for honing, and order up piston rings. If I don't need to notch the pistons, I'll send them off for coating.
So I've got a short block to tear down - I'm off to get some kerosene for the heater and a bunch of Zip-lock bags.
