I took great interest in Gary Hart and Mike Collison’s straight eight Buick build. If you haven't had a chance to look at it, here's a link –
http://www.landracing.com/forum/index.php/topic,4974.0.htmlMany of the issues they had to contend with were related to the shared intake ports on the Buick.
To that end, I'm fortunate in that my engine choice, though a 58 year old design, has had a lot of development work done on it both by the factory (BMC/British Leyland), and by numerous tuners over the years.
Back in the 1980’s, David Vizard and Dave Anton at APT started a program of cam development for the A-block, worked with both Kent and Crane cams, and eventually developed what they refer to as a “scatter pattern” cam for the A-Block.
It sets up different timing events for the 1 and 4 cylinders than the 2 and 3 cylinders to minimize cylinder robbing between the 1-2, and 3-4 intakes, maximize the charge and take better advantage of the shared exhaust port on the 2-3 cylinders and individual exhaust ports on the 1 and 4 cylinders.
I'm glad they did the work, because it was all I could do to try to put it in a sentence.
Dave Anton is still at APT, and we talked our way through it – He's a class act. The SPVP5 Cam specs out like this -
306 duration (nominal), .324 lift intake, .321 exhaust (1.5 rocker ratio)
Timing for cylinders 1 and 4 are as follows –
47.5 - 72.5 - 72.5 - 42.5 103.75 LCA
For 2 and 3 –
44.5 - 75.5 - 75.5 - 44.5 105.5 LCA
Something occurred to me after I ordered it. Unlike a “regular” engine, where you check valve to piston clearance on just one cylinder, I’ll need to check both the 1 and the 2 chamber for valve to piston clearance, as the events are not the same.
Pics when the new toys arrive.
