My fuel call fill plate had only a fill, pickup, and a vent that included a ball check roll-over valve-- no fuel return port. I'll need one to return fuel from the pressure regulator/bypass, so I took off the fill plate to add that port. It is a good thing I did; the fuel pickup inside the tank is at the opposite end from where I thought it would be. The pickup hose curved back to the end that is away from where the fitting is.
I drilled a 9/16" hole in the steel plate and added an AN8 bulkhead fitting, using the conventional O-ring and grooved nut to seal the hole. I was surprised that fuel-Safe sealed their holes on the outside by placing nylon washers under the bolt heads and fittings rather than on the inside with O-rings. They work, just different. Since the top plate seals against the cell with a rubber/cork gasket, I used a torque wrench to tighten all the 1/4-28 bolts to 40 in-lbs to insure they are clamping the gasket uniformly.
Now I need to re-work the holes in the side pod aluminum panel for the added return port. Onward....
Regards, Neil Tucson, AZ
