I think I mentioned how light air drills are, Mike. Speaking of air drills, I now have 286 #30 holes drilled un the aluminum panel and most are match-drilled in the steel chassis tubes. Some still need to be drilled into the chassis but my wrist has had enough for today. I used my pneumatic Cleco runner to install & remove the cylindrical Clecos. I sure makes that job easier. Thanks, Ingersol- Rand!
The best tool for installing blind rivets that I've found is a PT-100 made by FSI. It operates on shop air and generates 4500 lbs pull with its internal hydraulic pump. It is small and light and costs a fortune but used ones can often be found on eBay for prices that vary all over the place, sometimes as low as $50. The thing you have to watch is whether it includes the size tips that you need. Mine started to malfunction (it was low on hydraulic fluid) so I mailed it back to FSI and they rebuilt it for $80. I think that was a very reasonable cost to make it work like new. FSI also makes D-100, a manual tool that does the job and it can pull Nutserts with the right adapter.
Regards, Neil Tucson, AZ
