Dropped in on Max to see if he was doing anything, looks like the elves have been hard at work.
First the blower is in... lots going on here, top down, a Ron's toilet bowl, about a 1400 CFM (yep 1400) unit. It sits on a Max built distribution block with 4 injectors. These are on the "suck" side of the blower and are the atomizer type (they mix air with fuel) fan injectors. They spray about 30% of the fuel into the blower, cools the charge and the blower. Next comes the blower, massaged for about 25 PSI, Teflon wipers, clearanced, overdriven about 1.6 to 1. The outlet is another Max design, all this is mounted on top the tranny, notice it is also connected to the frame to prevent twisting.
Hard to believe the 1400? That thing will swallow your head. You can see the 4 injectors with little air filters on them in the front as well as the injector above the rotors in the blower. To the right is the distribution block for the individual cylinder injectors. As I said, there is a lot going on here. The injectors in the blower get 3 lbs of pressure for starting, the cylinder injectors don't get any until fuel pressure exceeds 8 lbs, part of Max's flood control project.
Here is a shot from the front. Of course you can't get a shot from the back, that is already hidden. The four hoses on the left go to the cylinder injectors. When you are building the smallest vehicle possible packaging is everything. Max's engineering leaves very little wasted space.
Hopefully I pointed out everything, if you see something you wonder about, ask, I'm sure Max will chime in and explain things a little better than I can. Of course, he might be a little busy with assembly.
