The pond at the end of the access road shouldn't be much of a problem this year. Intrepid, the new owner of the potash facility in cooperation with the BLM, put down enough salt to fill in the deep spot. Reports we have had say it is really not going to be a problem. I will second the comments about gently flushing the salt away. The car wash in Wendover recycles their water so you are putting salty water, under pressure, into the seams on your vehicle. Better to use Salt-X, WD-40 and such at home. I have used 5 weight motor oil from a spray bottle. Messes up my glasses and the shirt I wore needed 40 Mule Team Borax and hot water along with laundry detergent to get it clean after spraying on the oil. It does help however. I've used Salt-X in a spray bottle and solved most of my after exposure problems. A second hit a couple of days after the first doesn't hurt. Apparently the salt is very hard on the electrical connections for anti-lock brakes. There are horror stories about rusted brakes on trailers that don't get thoroughly cleaned until time for the next trip to Bonneville.
