For the 2008 BUB......it looks like we may well have at least 3 sidecar streamliners.................Max, and his twin-Vincent in the 2000c.c.c (or is it 3000c.c.) Craig Anderson and the Kiwi Suz. 1000c.c. and John Renwick using Turbo/Vincent1000cc. for power........................................................All may be running for FIM World Record...........It should be very interesting............................... Does FIM distinguish between pushrod and non?
I'm not sure, but I think that the Renwick Vincent is more than 1000cc. Like you say, It should be interesting, but I think you forgot somebody. How 'bout Noonan?
Quote from: Kansas Bad Man on April 08, 2008, 07:41:04 PMI'm not sure, but I think that the Renwick Vincent is more than 1000cc. Like you say, It should be interesting, but I think you forgot somebody. How 'bout Noonan?Max,"Noonan" will not run a streamlined sidecar...
Quote from: John Noonan on April 08, 2008, 07:52:52 PMQuote from: Kansas Bad Man on April 08, 2008, 07:41:04 PMI'm not sure, but I think that the Renwick Vincent is more than 1000cc. Like you say, It should be interesting, but I think you forgot somebody. How 'bout Noonan?Max,"Noonan" will not run a streamlined sidecar... Hey John, the way I see it you're the bad boy on the block when it comes to side cars, (and most everything else too) What's the world gonna do when you decide to put something in a bullet? The reason I threw you in the pot was that you're the man to beat. Max
