It was common for the vintage racers to push down a mile before they lit the fuse, and save the rest for another day.
The gas racers, if they were still running at the end of the week , would put a big load in it and push down a bit so nobody else would smell the mix.
They would often set a fast mark that showed up in the results under their gas entry, but pretend to have broken it and just go home.
The bikers didn't play with fuel that much, but sometimes wanted to try some inappropriate streamlining.
That is the reason the class designation was required to be put on the # plate so to keep everybody honest.
There is a reason for everything in the rule book, some are better than others.
Be sure and study, there is going to be a test.
