Author Topic: BB Bonneville Bugeye  (Read 156217 times)
0 Members and 7 Guests are viewing this topic.
Offline Crosley
Re: BB Bonneville Bugeye
« Reply #30 on: October 27, 2009, 11:13:42 PM »
I agree , very interesting front suspension.
Tony in AZ...
"If you find yourself in a ditch.... let up on the throttle"
Offline hotschue
« Reply #31 on: October 28, 2009, 07:28:38 AM »
Hello IB - Photo a little misleading rack will be welded to frame.  Have not determined steering column angle yet.  Bumpsteer should not be an issue since suspension travel will be less than 2".  Horizontal shock is a result of not having vertical clearance for a coilover shock, body will clear horizontal shock by 1/2".
Udo Horn
221.559 D/CGC '03
182.144 G/GMS 2019
« Reply #32 on: October 28, 2009, 08:55:03 AM »
With the rack being that wide, the tie rods will be very short, before you weld it all up, run the suspension through its range of motion, I think you will have a lot more bump and roll steer than you think.  The rack mounted on the axle will eliminate a lot of that but rack placement will need to be looked at to ensure the tie rods don't sideload the rack.  A sliding column is really quite easy and only has to more about a 1/2 an inch to follow the front end.
While you are checking the bump, take note of the lateral motion as well, that is also uncommanded steering input.
Great project, good luck with it  :cheers:
Offline hotschue
« Reply #33 on: October 29, 2009, 11:05:28 AM »
Thanks all, SS great idea will certainly look at that option when I get back to the steering.  Finished bulkhead/motorplate everything fit on the first try, wish all my fab worked that way.  Next, fab V-8 mounts, finish front and rear bulkheads install cowl.  Then the fun begins, having made my wooden bucks, will start to fab alum body.  Hope to make major strides in the next two weeks.....
Udo Horn
221.559 D/CGC '03
182.144 G/GMS 2019
Offline hotschue
« Reply #34 on: October 29, 2009, 11:29:24 AM »
FREE TO A GOOD HOME......My build table will be replaced by corner stands in about a month.....It breaks down into (2) 8' sections easily transported in PU truck.  Less than 1 degree deflection in 16' length very sturdy, got the idea from fellow LSR racers.  Great for a one off build!  Could not have done build without it. - Downside it's in Annapolis, Md.  Send PM... got to be some east coast builders!
Udo Horn
221.559 D/CGC '03
182.144 G/GMS 2019
Offline DSR Bruts
  • Salt Fever Reliever 1
« Reply #35 on: October 29, 2009, 02:13:47 PM »
If I lived closer, I would come over, but I'm in KC.  I built my own airplane and still miss my build table that I gave away to another airplane builder.  Sound leveled tables make for a easier job building the frame and so on.  Good Luck with the car.....keep up the posts.  You are doing a great job!  Bill
Bill and Ross Brutsman
778 D/STR
SDRC, BNI, SCTA, NSRA, SEMA
De Oppresso Liber
Offline hotschue
« Reply #36 on: October 30, 2009, 12:18:51 PM »
Another day working on bulkheads, couldn't resist had to install a set of heads and headers......It's starting to look like a race car!
Udo Horn
221.559 D/CGC '03
182.144 G/GMS 2019
Offline SlyOneJr
« Reply #37 on: October 30, 2009, 08:18:13 PM »
Looking good Udo!  Keep up the great work!  Keep the pics coming!
Jeff
New Guy building a L/Gas Lakester
Ninja 250 powered Lakester for ECTA meets
Offline hotschue
« Reply #38 on: November 01, 2009, 07:12:42 PM »
Spent the weekend mounting cowl to center bulkhead and locating rear body shell.  Cowl is the base for mounting and locating body front to rear.  Now for the inner structure and front alum body fab...
Udo Horn
221.559 D/CGC '03
182.144 G/GMS 2019
« Reply #39 on: November 03, 2009, 10:58:54 AM »
Hotschue,
It is "starting" to look like a race car but don't start thinking you are close to being done. As you know doing the details, wiring, brakes, fuel lines etc will probably take as much time or more than the initial fabrication. Looking good though! keep us posted.
Offline hotschue
« Reply #40 on: November 05, 2009, 06:11:50 PM »
Last couple of days working on motor mounts and rear body mount.  Lift off rear mount no tools required.....tomorrow finalize mid plate mounts and start to hang rear sheet metal.
Udo Horn
221.559 D/CGC '03
182.144 G/GMS 2019
Offline hotschue
« Reply #41 on: November 12, 2009, 03:07:53 PM »
Hmmm......guess I'm going to need a second U joint.
Udo Horn
221.559 D/CGC '03
182.144 G/GMS 2019
Offline Crosley
« Reply #42 on: November 12, 2009, 04:10:24 PM »
naw...  a couple of synthetic straws and high speed duct tape will be fine  for a flex joint there
 :evil:
Tony in AZ...
Offline hotschue
« Reply #43 on: November 16, 2009, 05:59:00 PM »
Finally....front end is conquered....moving to the rear assy.  Did a dry run today located shock/track bar mounts...ordered axles from Moser, hopefully straight forward no surprised. Will keep me busy for a few days.
Udo Horn
221.559 D/CGC '03
182.144 G/GMS 2019
Offline hotschue
« Reply #44 on: November 19, 2009, 02:34:06 PM »
Got the rearend hung, except for final welding, everything as planned no surprises....fun begins tomorrow....start to hang the body....
Udo Horn
221.559 D/CGC '03
182.144 G/GMS 2019
