Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Calendar
Login
Register
Landracing Forum
Tech Information
Technical Discussion
(Moderator:
boost temperatures
« previous
next »
Pages: [
1
Go Down
Author
Topic: boost temperatures (Read 2213 times)
bvillercr
boost temperatures
on:
February 06, 2008, 06:28:45 PM »
This is how we keep track of our supercharger efficiencies. The % are the efficiencies i.e 45%, 65%, 75%. Also these charts show the different temperatures between 70, 90 and 100 degree ambient temperatures. This is just the compression of air before any inter-cooler or fuel is added. What kind of temperatures are you seeing?
I had to break each page into two parts so you could see the numbers better. We got the formula from Hugh McGinniss Turbocharging book.
Last Edit: February 06, 2008, 06:36:23 PM by bvillercr
http://www.procharger.com/
jl222
Re: boost temperatures
Reply #1 on:
February 06, 2008, 08:52:52 PM »
The ideal temp on the charts are considered 100% efficient at that boost level, in other words you can"t compress air any better than that.
bvillercr
Reply #2 on:
February 10, 2008, 09:48:05 AM »
We found another chart that is more relative to Bonneville. The pressure is dropped from 14.7 sea level to 12.7 for the altitude adjustment. The temp. at 30 psi is much higher at altitude than at sea level. The temp. of the day would be during the morning sense it is only 70 degrees.
Only time and money prevent completion!
Reply #3 on:
February 10, 2008, 02:18:00 PM »
Your charts certainly are a strong argument for proper sizing of the blower to the application for the most efficient engine/blower setup and also for BIG liquid to air intercoolers! Great info!
jl222
Reply #4 on:
February 10, 2008, 03:56:19 PM »
also why centrifugal or turbos with 65-75% efficiency run so much faster than roots blowers "on gas" that are 50% or less,some new designs are getting better though.
Pages: [
1
Go Up
« previous
next »
Landracing Forum
Tech Information
(Moderator:
boost temperatures
