Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Calendar
Login
Register
Landracing Forum
Tech Information
Technical Discussion
(Moderator:
aftermarket motorcycle CDI box availability
« previous
next »
Pages: [
1
Go Down
Author
Topic: aftermarket motorcycle CDI box availability (Read 2763 times)
Dave Cox
on:
January 16, 2008, 12:28:54 PM »
Looking to put together an older (2001) ZX6 Kawasaki Ninja for El Mirage and Bonneville. It's still carburetted but uses a CDI ECU box. I've been looking for an aftermarket box but none seem to be available. Does anybody know a source or should I go with the stock European CDI and a 4 degree advance plate? We're looking to run in the stock class.
Thanks!
Dave
Last Edit: January 16, 2008, 12:54:05 PM by Dave Cox
www.worldlandspeedrecord.com
1212FBGS
Re: aftermarket motorcycle CDI box availability
Reply #1 on:
January 16, 2008, 01:08:08 PM »
Try searching the great Britain and French ebay listings you should have luck there... try Marc Salzburg at Factory Tuning in San Rafael Ca, he may still make the ignition advancer
Kent
Larry C
Real sidecars have passengers
Reply #2 on:
January 16, 2008, 02:59:04 PM »
You might also try Schnitz Racing and Orient Express. They are motorcycle drag racing supply companies and may have something or be able to steer you in the right direction.
Dave Cox
Reply #3 on:
January 16, 2008, 04:52:24 PM »
Thanks guys, I'll do some checking.
Kent, do you have "stock" replacement fairing pieces for this bike? I'm missing a couple.
Thanks
Dave
1212FBGS
Reply #4 on:
January 16, 2008, 08:27:04 PM »
most of it... see here
http://www.airtech-streamlining.com/kawiz/ZX6R2000-02.htm
call lme if ya need somethin
kent
Pages: [
1
Go Up
« previous
next »
Landracing Forum
Tech Information
(Moderator:
