Doug,
I am NO scientist, however, I listened to Dennis at the GasUp too, and the part that I don't get looks a bit like this: Let's say there is 100 PSI in your tire. And let's say that the volume of your tire is one cubic foot. That means there is six cubic feet of air in your tire. Now air "weighs" or has a "mass" of around one ounce per cubic foot (at sea level for the ng-i-neer types, okay). Now that means there is six ounces of air in your tire. Now I'll grant you that those little molecules have weight, and I'll also grant you that a little can mean a WHOLE LOT when the tire is spinning 4000 RPM (300 +/- MPH) but we're talking, in the case of a 26" tall tire with three inches of contact width, of 245 square inches of surface area for that six ounces to press against.
Now I will also grant you that dry air has less "weight" than Bonneville air when the salt is damp, and I will most likely convert to pure Nitrogen just for this reason. However, I still believe that the extra tire pressure does more to prevent the bead from coming off of the rim than to cause it. And to be clear, I say, "believe" because I have not tested, but I have heard the same story from a number of olde salts. (Doesn't mean it's true
Incidentally I've been over 230mph with a flat front tire (21"... 3600rpm) and it didn't pull off the rim. Perhaps because it was so "short" and so stiff. My co-driver reported the car handled "kinda funny" so I took a pass to check it out and, son of a gun. What do you know? Thought those things were supposed to hold air for more than a day (there was a poor bead seal as it turned out).
Anyway, I'd be VERY interested in hearing from the Goodyear guy if they did anything new to the Land Speed tires since 2004.
Jim
