Bonneville is event gas. Don't bother bringing your own.
Sockjohn, you can't guarantee the same gas from the same vendor at two different locations. Different days at the same station will vary. Winter gas is different than summer gas. This has been tested and verified.
El Mirage isn't event gas. The gas should be tested in tech inspection so you don't waste run time and parts only to be turned down at post race. Kent, the gas that failed last year will not only pass next year, but won't be competitive. The rules say 10% methanol, but I'm going to guess you can run more.
I think to be competitive you will need your own DC meter so that you can tune your fuel.
In case that confuses you, the old DC maximum limit of 2.3 limited you to gas with a tinge of something else if you wanted to crank it up a little. Some of the race gas passed, some didn't.
With a DC of 15 next year, virtually all race gas will pass, and if it isn't oxygenated you won't be competitive. Forget gas only. Adding Methanol with the oxygen it carries will add a bunch of horsepower. How will you know what is competitive? Here is a list compiled a while ago by Precision Fuel Testing Systems. They sell fuel testing equipment.
http://www.ridgecrest.ca.us/~hideseng/dc_list.htmThe higher the DC, the higher the oxygen (or other compound) content, the faster it goes.
Racers have taken weather stations for a long time to be able to tune the gas to meet the available air that changes with heat, humidity and elevation. Taking a DC meter to tune your fuel mix to the maximum power available is just the latest twist.
