Don't confuse wheelspin with horsepower. Build a car with solid suspension or put to heavy springs on a car with supension put 70 lbs. of air in the tires,set the 4link or latter bars so the instant center is in the wrong place and you can spin the tires to your hearts desire. 0f course you could add 4000 lbs. of lead.
Msd has an ignition that enables you to set how fast the engine accelerates. Mustang racers at the drags on 10.5 inch slicks have exceeded 200 mph with that system, but not before.
Wheelspin definitely causes oversteer and possible spin, but lack of downforce at speeds over 160 mph is
another problem, spoilers,wings,& weight are required.
To answer the post, probably? We have run 288 mph with a 279 exit speed in our Camero, the car weighs 4680 lbs with 3000 lbs. on the rear tires & 10 inch spoiler. The car handles great at that speed with no wheel
spin after shifting out of low gear. It is possibly too glued in but no weight will be removed at this time. I HAVE NO DESIRE TO SPIN THE TIRES, or get too light.
If the record was close and slower speed ?
jl222
