Talk to Ron Main about TC. If the TC gives up the ECU may think that the rear tires are going 250 and the front tires are at 0. Take some lead out to compensate and you have EGTs in the 1700 deg. range., or something like that.
Not a fan,
I think traction control is a great thing personally. Ron Main's malfunction is an example of how it should NOT be programmed. The front speed sensor broke, thus giving the ecu a 0 wheel speed in front and like Dan stated 250 something in rear. It would have worked beautifully if it was programmed different.
First, they took all the timing out to compensate for the difference in wheel speed. This is the problem. It took all the timing out and caused some extremly high exhaust temps, literally baking off header wrap. This in the end (my assumption) caused weakened valves and on next run they broke valves.
If this was programmed different they would not have had this problem and motor would have lived the rest of the week.
A better solution would have been to start killing injectors, no fire, no heat and you would have ended up with an aborted run instead of a motor failure.
The technology is there to do it, and make it workable.
Jon
