Author Topic: TH400 to manual transmission replacement  (Read 6657 times)
Dirt
« on: October 06, 2007, 04:55:09 PM »
Need to remove a th400 from a car and replace it with a manual transmission, anyone know of a suitable replacement, it's for a 6000lb vehicle.
Offline doug odom
    • popmotorsports.com
Re: TH400 to manual transmission replacement
« Reply #1 on: October 06, 2007, 05:31:32 PM »
6000 pound car?  What is it going to be used for?      Doug Odom in big ditch
Dirt
« Reply #2 on: October 06, 2007, 11:28:41 PM »
It's a 76 Rolls Royce Silver Shadow, it's a heavy car.
« Reply #3 on: October 06, 2007, 11:51:04 PM »
Try to find some of the NASCAR teams they sell their used stuff for a very reasonable price and most of it only will have one race on it. Their trannys can be had at a pretty good discount over a new one and they are state of the art and will take 850 hps on a 3400 lb car.
« Reply #4 on: October 07, 2007, 12:46:24 AM »
Just curious, why would someone want a manual transmission in a Rolls Royce Silver Shadow? The turbo 400 can be built to take any abuse a 6000 lb. car can give it. They were standard equipment for crewcabs with 454 chevys that towed some very heavy trailers in stock form.
Offline russ jensen
« Reply #5 on: October 07, 2007, 01:19:06 AM »
 GM has a real tough 4sp tranny- suburbans w/ towing pkg & pu's- has a low gear for pulling stumps.
speed is expensive-how fast do you want to go?-to soon old & to late smart.
« Reply #6 on: October 07, 2007, 10:27:30 AM »
Russ are you talking about the 4L80 E that is based on the 400??  Here are it's ratios:
4L80E..................2.48.....1.48....1.0.... .75
The 700R4/4L60/4L60E/4L65E is the one with the low first and higher overdrive:
700-R4/4L60.......3.06.....1.63....1.0.... .70
It isn't as strong, but my truck is over 5800 lbs. with the truck and teardrop and I have used a "built" 700R4 behind it with no problems and it has 140,000 miles on it now with 45,000 miles towing.
I agree with Tom though that the 400 could be built plenty strong, but maybe the person just has to have a manual.  If so I would look at one of the 6 speeds from a viper or vette for a road transmission (Borg-Warner T-56 transmission or the Tremec TR-6060 transmission which has succeeded the T-56 for some applications).
c ya,
Offline DCarr511
« Reply #7 on: October 07, 2007, 04:49:33 PM »
What gear ratio's are you looking for ?
Offline russ jensen
« Reply #8 on: October 09, 2007, 11:06:50 PM »
c ya,
NO- talking 4 sp manual heavy cast iron-very tough tranny as trk pullers shell out several rockwell rears & tranny keeps on ticking. Don't know for sure but think they are new process. bought a 80 surburban just to get tranny.bty the turbo 400 are plenty tough- have one behind 392 in tractor w/ 0 problems.
« Last Edit: October 09, 2007, 11:10:13 PM by russ jensen »
