I just finished a layup over (everything I could find - plexiglass, styrofoam, foam in a can, florist foam (easy to shape) and drywall mud (yes - it took a long time to dry) masking tape), wrapped it all in saran and went at it with cloth and resin.
This was my first time. It was fairly easy. It looks like hell.
It will take a lot of filling to make look half decent - which is where I will stop. This is my 'tester' project.
If I had it to do over I might do it like
http://www.recumbents.com/wisil/wianecki/frank-n-liner/default.htm (but I've never done it this way either, and by the time I get done I may have different ideas). I will use the build up design as a plug for a female mold, and then layup the 'real' body in this mold.
Second option is to use Kent's friend that has a big 3 axis mill to cut a female mold out of a big block of foam. Skin it, release coat it, and then use that as the mold to lay up the body. Probably pretty accurate, but somewhat expensive for the mill work.
I second the 'this is a lot of work' statement. As a matter of fact - this is a whole hell of a lot of work. And more. Take whatever time you have allowed for this and multiply by 10. I thought I'd knock this out in a week and a half. MONTHS later it's still not done. (Now, I'm learning as I go, but there have not been any show stoppers, it just takes time.)
I think the biggest problem is getting 2 sides the same shape (or two anythings the same shape for that matter).
Jim.
Oh yeah. make sure that saran is stretched really smooth. Every wrinkle shows up. And, epoxy will stick to dry drywall mud, and you will never get all the drywall mud off.
