OK, here's the deal.
I decided to start a new topic in the tech side but is really a continued discussion of where the wheel base, steering question on another thread.
I wanted to firstly say thanks for the comments and the work that sum put into editing the pics.
THanks....seriously.
Now for my crazy idea, take into consideration that I am not the smartest guy in the world (barely graduated HS!!!) and what I am about to suggest goes agents the grain of traditional thought in LSR.
It is a well known train of thought that in LSR it is a good idea to keep all air from going under the car. And I understand the reasoning and principles that make this common idea a good basis for most LSR cars.
In my quest to design a nose for my car I continually ran into a design problem. For some reason I think I an aerodynamically blanced nose would be a good thing. I think I have found a solution for that problem that seemed to have at, least in my mind, some merit.
Because I am not an aerodynamic engineer or have never seen this done I have a feeling that it is not done for a reason. I would like to know what that reason is.
My car, unlike a streamliner, is basically twice as wide as it is tall (referring to the front end of the car).
This means that if I were to build a nose that diverted the airflow 50/50 over the front of the car (25% down each side and 50% over the top) this would mean that 50% of the flow over the top would be generating downforce.
For some reason I got in my head that having a car in motion being 100% aerodynamically neutral in the front would be a good idea. This would mean that the 50% flow over the top would need to be balanced by apposing pressures of equal values.
My idea is to have a small area under the nose to allow a small amount of air under the car. This air would generate a given amount of pressure that would be then directed to the side by a dam the same or near profile as the front. The area between the nose tip and the "under dam" should generate a ground effect and could be very small in comparison to the amount of surface area and angle of deflection of the air going over the top. I listed a raise of 4" on the drawing but it could be less then that and should not significantly increase drag because of the small amount of air going under the nose and the efficiently of the lift generated by the ground effect.
This in my mind would, or help equalize the pressures on the front of the car so when the car would be in motion that each side would get a 50% of pressure and the top and bottom would get equal pressures and still prevent the air from actually going under the car....at least beyond the front wheels.
Is this a crazy idea and should I just stick with a standard nose shape like the examples pictured in the other thread.
-JH
http://www.fiatforum.com/gallery/data/500/medium/lowered_with_nose.jpg?2741
