Guys,
I appreciate all the help since I'm shooting in the dark on this one. I dyno all the engines for a local high performance oriented machine shop and have seen just how effective header tuning can be. I've seen a torque increase of 96 lb/ft at 4500 rpm on a 406 SB Chevy when collector extensions were used.
I'm trying to build a top of the line engine: aluminum rods, custom light weight JE pistons, aluminum roller rocker arm assy, external oil pump, etc. I'm not cutting any corners and think the correct exhaust can make or break this engine.
David Vizard and I go way back (he's my guru) and he didn't think his knowledge of the 4 cylinder engines would be of much help on the GMC. I have both of Philip H. Smith's books on exhaust systems. I also have Roger Huntingtons book on the GMC. I gleaned some info from Smith's book but not enough to be 100% certain what to do.
I'm thinking I may have to fabricate a universal header flange that will accept different header configurations and dyno the engine with each configuration, then tune the one that looks best.
Damn, why didn't I take up ceramics or knitting instead of cars.
Thanks guys, Ron
