Air is a fur shur variable and while you think you have it figured out, it or you changes, then it is a whole new ballgame.
Vehicles that really fly across the salt, REALLY FLY, when the apparent direction of the wind changes.
Ask the "Frequent Fliers" that use ground effects for suck.
Airplanes can correct the point of the craft and still go the direction they want with some loss in efficiency..
Vehicles in contact with the ground don't have that luxury without some way loss in stability.
I had a Corvair Turbo that could beat the Pushes of the day in part because I had two 80lb. sacks of cement in the front trunk and didn't have to be afraid to drive it.
