Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Calendar
Login
Register
Landracing Forum
Tech Information
Technical Discussion
(Moderator:
spools verses posi track units
« previous
next »
Pages: [
1
Go Down
Author
Topic: spools verses posi track units (Read 6631 times)
stratman59
on:
June 26, 2007, 08:09:38 PM »
I'm getting ready to build a car and after reading several posts about cars spinning at high speed with spools was thinking about running a posi unit instead
any thoughts would be greatly appreciated
thanks
robbie
doug odom
Re: spools verses posi track units
Reply #1 on:
June 26, 2007, 11:22:32 PM »
What type of car? What is the wheelbase? What is the tread width? All LSR cars are not the same, and require different systems to work correctly. What works for a 108"wb GT car is not really the best for a 216"wb liner.
Doug Odom in big ditch
stratman59
Reply #2 on:
June 27, 2007, 06:38:51 AM »
we are building a plymouth laser for a/gcc not sure on the wheelbase yet
its going to be longer than stock for stability
what i was trying to say in my original post is the car is getting out of
control due to the tires spinning and wouldn't it be safter to run a posi
unit instead of a spool
thanks
robbie
Richard Thomason
Reply #3 on:
June 27, 2007, 06:46:17 PM »
All types have been used. There is no clear cut winner or loser here. Sorry, that is not much help I know.
SCTA/BNI timer 1983 to 2004, Retired,. Crew on Tur
Reply #4 on:
June 27, 2007, 06:56:48 PM »
A lot of the spins are because the driver starts to chase the vehicle instead of letting it drift a little and not over correcting, it's not easy but there are no walls to hit and easing it back on course in the room we have can save it in a lot of cases. Every car is different and takes the driver some time to get used to how it handles at speed.
doug odom
Reply #5 on:
June 27, 2007, 07:31:04 PM »
Robbie, If you install a 2 to 1 roundy round car type steering quickener backwards it will slow the steering but let you turn as much as before. Just takes twice as many turns on the wheel to get there.
836dstr
Reply #6 on:
June 27, 2007, 07:44:00 PM »
The power and torque output can make a big difference. We have a club member running a AA/STR that was having a hell of a time going straight. They were using a posi. They found the culprit was a set of mismatched tires. The rolling diameters were slightly different causing the car to want to go left.
It's the little things you don't check that cause some interesting problems.
stratman59
Reply #7 on:
June 28, 2007, 06:38:21 AM »
thanks for the input
doug that's a good idea i never thought about
tom i have had that problem with a drag car and it drove us crazy
things learned the hard aren't easily forgotten
glen i was wondering about that do and its probably a easy thing to do
running speeds over 200mph
thanks again for the ideas
robbie
Richard Thomason
Reply #8 on:
July 16, 2007, 05:32:19 PM »
On our checklist, before every run, we check rollout and adjust tire pressure. Don't know if it helps, but it sure hasn't hurt so far. Mickey T's were notorious for not being matched sets. When buying tires, always insist on matched sets.
jimmy six
Reply #9 on:
July 19, 2007, 01:45:17 AM »
When you are done and the car spins and you have a spool/posi/equal-lock/Detroit locker take it out. If you have an open rear and you spin put one in.....Good Luck
Pages: [
1
Go Up
« previous
next »
Landracing Forum
Tech Information
(Moderator:
