$1000.00 Good fire suit
$1000.00 Simpson helmet / $1200.00 Hans device
$140.00 Gloves
$150.00 New shoes (why not can't have to many pair of those)..........
Don't forget the fire bottles, chute, belts......
I don't know about a Hans in a lakester if you are in a lay-down position. I think they have a minimum angle they want you to be at. Let me know what you find out. Did you read the "Burkland" data. I'll have a helmet stop like he recommends and hope that does what the Hans would do more or less.
...........................I got a price of $2140.00 for the quick change rear end (100lbs axle -axle) I want to use and the gears are $101.80 each.............
What kind of quick change is this??? Got a link?? What is the ring/pinion gearing?? How tall of gears can you get?? I'm helping a guy now that got a quick change and thought he would be set, but it has like a 4.86 ring and pinion and the tallest gear is like a 2.73. Might just work for him at first, but won't be tall enough for the future. I think he can get a 4.11 ring/pinion for it, but that still isn't good compared to a V-8 quick change with about a 3.73 (??) ring pinion. A lot of the quick changes are for circle track guys that wind the motors high and run really low gearing go get off the corners. We don't have corners
. Have you run your gearing through my spreadsheet for 5 or 6 speed bike motors??
http://purplesagetradingpost.com/sumner/bvillecar/bville-spreadsheet-index.html...................I called about a salvaged 2007 zx-14 motor w/ ecu and wire harness for $3500.00 (little on the high side IMO) will keep looking.
Thanks for words of motivation...John
Looks like it is time to change brands where it isn't quite as expensive for a motor and there are more speed parts
Probably didn't want to hear that
