Author Topic: my 1000cc APS/BG project.  (Read 19510 times)
Offline panchop
« on: May 28, 2007, 09:38:17 PM »
my starting point.
built a turbo system.
turns out all that is good from the engine is the crank, tranny and heads. the cases needed welding and the heads will be ported . i am ordering pistons from JE this week, my freind Sam Teranova from Turbo Tec USA is doing all the engine work. I have done some more on the body and frame.
I was not happy cutting up the brand new beasly ZX-11 body
added seat material to the aluminum center section I put in the body and caulked in the seat pan.
i added body mounts to the frame for the main body.
I fited a ZX-12 front fender. not sure how to mount it. I had to modify the hell out of the sliders to get it to fit.
I haven't figured out the front fairing yet. i will need to fab some brackets to hold it in place.
I had to cut away a bit of the fairing to clear the fork legs. I still need to fab up a set of handlebars. probably extend them forward as much as I can fit in the fairing.
Wheels on in front of my crappy old free trailer.
I need to make a belly pan , a  chin fairing and all kinds of stuff still. Time is getting short.
« Last Edit: May 28, 2007, 09:57:26 PM by panchop »
Re: my 1000cc APS/BG project.
« Reply #1 on: May 28, 2007, 10:58:17 PM »
You've been real busy  :-D.  What kind of turbo.  Is it going to be blow-thru on carbs or you using throttle bodies with fuel injection??
You'll make it way before me  :-) ,
Offline panchop
« Reply #2 on: May 28, 2007, 11:10:00 PM »
it's a small Mitsubishi blowing threw 34mm Gixxer CV carbs
Offline panchop
« Reply #3 on: July 03, 2007, 03:08:11 AM »
stretched the frame 8 inches, reinforced that part of the frame while i was at it. checked for straightness and leveled the whole thing . lots of work, not a very inspiring picture. LOL
« Last Edit: July 03, 2007, 03:09:49 AM by panchop »
Super Kaz
« Reply #4 on: July 03, 2007, 09:41:47 AM »
panchop,
I thought that Garage looked familiar :-o!
Sam's AWESOME,and has built me some Cool V-rod Motor's 8-).
Now if I would keep them in 1 piece I'd be Cool :wink:!
Good Luck and see ya on the Salt :|?
Kaz................
Offline Xea
« Reply #5 on: July 03, 2007, 10:03:52 AM »
Tell Sam hello from Scott, the fat guy with the Buell. Sam is one sharp cookie! See if you can talk him into coming with you to the salt.
Faster, till the thrill of Speed overcomes the fear of death.
« Reply #6 on: July 03, 2007, 01:36:30 PM »
My real question is did you keep the Husky tank????
Offline panchop
« Reply #7 on: July 05, 2007, 02:05:22 PM »
nope husky tank is in a bucket in the shed.
new rear of frame. longer, lower and stronger.
shear plates and paint.
body now mounts in six places.
Offline whitworthsocket
« Reply #8 on: July 11, 2007, 10:37:53 AM »
Hi Panchop,
Nice looking machine!
A couple of questions. Are the mag rims standard production items?
What tyre's  (size, make and speed-rating) are you running?
What  kind of fasteners are you using to mount the body?
Regards Whitworthsocket
Regards
Whitworthsocket
Offline joea
« Reply #9 on: July 11, 2007, 11:33:05 AM »
another INSPIRING effort..........
WAY TO GO..!!!
Joe :)
Offline panchop
« Reply #10 on: July 26, 2007, 12:19:10 AM »
Hi Panchop,
sorry for the delay.
mags are from a Suzuki GS 500 , tires I am using are used takeoff Z rated sports touring tires. front is a Michlean 120/70 17 rear is a Metzler 150/70 17 . i am using Moroso  fasteners.
working on a belly pan., and front fairing lower.
« Last Edit: July 26, 2007, 12:22:19 AM by panchop »
Offline panchop
« Reply #11 on: August 13, 2007, 11:36:14 PM »
up and running. i miscalculated the  gearing though. didn't figure in the primary ratio.
« Last Edit: August 13, 2007, 11:37:59 PM by panchop »
Super Kaz
« Reply #12 on: August 21, 2007, 11:41:00 AM »
I've Tried he's to smart for that :wink:!
Offline panchop
« Reply #13 on: August 27, 2007, 03:33:49 PM »
after two trips to the dyno, half of each day spent chasing electrical gremlins ( i pulled off the DYNA 2000 and switched back to an old DYNA S which solved my electrical issues ) i ended up making 205 hp / 115# tq. at about 9500 RPM. hopefully i can put that to the ground and make some decent passes. on the downside when everything went together all of a sudden my body didn't fit. I had to do some cutting and fiberglass work but at this point i don't have the time to make it pretty
« Last Edit: August 27, 2007, 03:35:35 PM by panchop »
Offline Jonny Hotnuts
« Reply #14 on: August 27, 2007, 06:00:50 PM »
How much boost?
Love what you have done so far.
-JH
jonny_hotnuts@hotmail.com
*Andres Segovia
