While the front of the car is very important the rear of the car is more important. The aerodynamic performance of the racecar depends more on the design of its rear than its front end, in a proportion of 6 or 7 to 3 or 4.
As the front of the racecar pushes the air in front of it, thus creating an area of higher pressure, which tends to slow its forward movement, what is less well-known is that an area of extremely low pressure is created in the racecars wake that slows down its forward movement by applying a suction or parachute breaking effect. This is the reason that the design of the rear of the racecar gets great attention from aerodynamic engineers.
This is also the main factor that explains the difference in Cd between versions derived from the same racecar with a cam back, square back, tapered back and others, that all have the same front end, but not the same rear, which accounts for significant differences in Cd.
The Devil Is In The Details.
