........... don't forget "English" is my second language and sometimes it's to find the right words................
And by the way, a truck (like the Phoenix!) could be much more aerodynamic than a lot of lakester with all his corners and dents in the body......
You are doing fine with your English
and if you would only post more I could get better at reading it
. You should hear my German
. I "was" married to a German and since we had so many tourists from Germany in the store at the beginning I tried to learn some. Of course being German she was a perfectionest and if I didn't say something exactly right I heard about it. I gave up learning from her and learned from my customers. If people gave adults the same leeway to make mistakes as they do a kid a lot more of us might learn a second language.
I think there might be other cars that can be made with a lower overall Cd than a lakester, but with the lakester you can also work with the frontal area, so I still think a lakester could have the second lowest CdA (note the A) behind a streamliner.
Sum, how much FA are you gonna have?
Should be a little less than 5.5 square feet for the main body and the pods going down the sides (similar to Seth's) 2 square feet for the tires as seen from the front, then you decide if you should add another 2 square feet for the rear ones that are right in line with the front ones.
I figure on getting the tires out there where they will have their own drag, but not much you can do with that although I've looked a little at what F1 does to fill in the air behind the tire and might experiment with that later. Now the body I'm trying to make with as small a frontal area as possible and trying to make it as aero as possible.
It is easy to say "when I build one of these I'll do this and that and these other guys have left a lot on the table", but when the time comes to fit you, the engine, safety equipment and everything else real life intervenes and you start deviating from that perfect concept you have in your mind.
The most common I've heard is "I'll make the body a neutral low drag airfoil as seen from the top". Sounds good, but about the only car (and it is a motorcycle) I've seen achieve that is Eric and John's motorcycle streamliner. The next best are EZ-Hook, BUB 7, Ack Attack, and the Easy Rider Streamliner. John and Eric's streamliner has some things in it's favor, the two riders/drivers are not big, they run a very small motor, and they are running a motorcycle streamliner that allows smaller cage members. Try the same approach with a lakester and you have the wheel/tire deal to deal with, suspension or no suspension, axle locators, physical engine size with engines over 1000cc where now the engine might be bigger in frontal area than you are and the safety equipment (especially the chutes) you have to deal with and the car becomes so long that to make it a good airfoil as seen from the top requires the car to get quite wide. Welcome to the real world
c ya,
