You have two issues going on. The higher pressure at the base of the windshield only extends forward about 1/3 of the length of the hood. The lowest pressure on the top of the hood is only 18 inches or so farther forward about 1/3 of the way back from the front of the cars nose. Due to that you have strong lift on the front third of the nose, and moderate pressure on the rear of the hood.
You also have air packing under the hood at high speed, which raises the pressure in the engine compartment. All the air that gets pushed through the grill needs to find its way back out of the engine compartment. Usually that is a long and high drag path past the engine, headers, steering gear etc and out the bottom into the slipstream under the car. At some high forward speed, the air coming into the engine compartment is more than the air that can get out, and you pressurize the under side of the hood with all that air waiting its turn to exit. The combination of positive pressure under most of the hood due to air packing and low pressure over the front 2 ft or so of the hood results in a very substantial lift on the hood.
If you look at some of the better automotive aerodynamics books they discuss the problems of "internal drag" A good example of the effect is how your ears pop when you roll up the windows at speed and the air flow through the cowel vent pressurizes the cars interior slightly.
If the low pressure on the front of the hood is only .5 psi below ambient air pressure over an area of 3 ft wide and 2 ft long, you have 6 square feet of hood with 864 sq inches and .5 lbs per square inch that aerodynamic lift is 432#. Now add another .5 psi positive pressure under the same area of the hood and you have 864 lbs of force trying to open your hood.
The under hood pressure and high pressure area at the rear of the hood will mostly cancel out as they will both approach the ram air pressure.
If you put a water manometer under the hood and ran the car at speed you might be surprised how many inches of water pressure you develop even at highway speed if you don't close off a large fraction of the grill opening.
Larry
