All -
Marvin Rifchin is the Wizard of Watertown, MA, better known as "Mr. M&H Tires" and he was a great guy to shoot the breeze with back in the 70's at NHRA events. Glad to hear that he is still doing well.
As to Kevlar, I might have an explanation for some of the "bad stories". Kevlar fibers are extremely strong, and they have virtually zero stretch. Mountain climbers use Kevlar ropes to haul gear up the cliff faces, because the rope can be very thin and lightweight, and have great resistance to abrasion. However, they don't EVER use Kevlar for climbing, because if the climber ever fell while attached to a Kevlar rope, when the rope went taut it wouldn't stretch to absorb the shock, and the climber would be dead.
That property of non-stretchiness was explained to me by a designer of climbing gear. That industry tried using Kevlar to reinforce things like backpack straps and handles on gear bags. They imbedded the Kevlar inside the Cordura (nylon) webbing and fabric. However, they discovered that when stress was put on the fabric, the nylon fibers stretched while the Kevlar didn't. The Kevlar fibers would cut through the nylon fibers like a knife, and the material would fail.
He also related that a few years ago a maker of the big whitewater rafts like they use in the Grand Canyon tried reinforcing the rubber / nylon / rubber construction of the raft body with Kevlar fibers. The rafts were very lightweight and rugged, but after a while they started getting blowouts. What they determined was that every time the raft hit a rock and stretched the raft's skin, the Kevlar fibers sliced through the rubber from inside. Eventually, the hole made it to the outside.
What does this have to do with tires?
Here's my speculation - if there is a lot of flex in the carcass of the tire (either heavy cornering loads or "growing" at high speed), the rubber of the tire might be sliced up by the Kevlar fibers. If that happened at 300mph, it would not be a good thing. Hopefully the makers of the new LSR tires have a solution to that potential problem.
Clay Taylor
