Hey,Kaz.Try this one ,it has Vrod specs in it.
http://www.rbracing-rsr.com/gearspeed.html
I tried and got this?
Drivetrain and Speed Calculator
Definitions:
Your primary drive, transmission and rear drive sprockets all combine to determine your cruising rpm as well as your final top speed. This calculator will show you your speed in each gear from everything from a stock bike to an all out drag bike with a separate jackshaft as well as the one we love the most, the Bonneville racer. The big end is where it's at!
Engine RPM -- You can enter your final redline figure or any other rpm, say the rpm you want to cruise at for a given speed, and the calculator will help you figure out the transmission and sprockets you will need.
Primary Drive -- This can be the oem compensator sprocket which is connected by a double row chain to your clutch...or a belt primary which comes in a variety of pitches and widths. In any case, it's a front and rear sprocket of some sort. One end at the crankshaft and the other end going into the clutch/transmission.
Transmission -- Four speed early items, five speed later transmissions, aftermarket six speed gear sets, two speed and three speed planetaries, high gear only Pro Dragsters...there are lots of options out there. Enter your given ratios and see what your speeds are.
Jackshaft -- Some drag race bikes and some Bonneville designs will use a intermediary jackshaft either to gain an offset to clear a wide tire or to prevent a final drive chain from being "too long".
Diameter of the Rear Tire -- You need to know the height (diameter) of your rear tire when properly inflated.
Tire Growth -- At speed the tire will grow. For regular road tires the effect is neglible but for the larger drag racing slicks it is considerable. As the tire expands your final drive ratio changes. In effect the tire becomes a variable gear and part of your "transmission".
Wheelspin -- In drag racing and at Bonneville you are going to have a percentage of wheelspin you are going to have to plan for. This will depend on a lot of factors which have to be determined, mostly through experience. You will have to gear "taller" to achieve your desired trap speed. For drag racing with ultra high horsepower apps like our 113 ORCA Turbos this should be about 5%. For Bonneville where traction is a variable depending on salt conditions you may have to figure in 10%...i.e. rear wheel going 220, front wheel going 200.
1st 2nd 3rd 4th 5th 6th @RPM
Engine RPM rpm Enter your target RPM. This may be peak rpm at redline or any other rpm. If you plan your bike to cruise at a certain rpm band where your engine is smoothest or where your torque band is at some optimum point choose this to work out your gearing.
Front Primary teeth OEM compensator sprocket or belt drive pulley. Early big twins 24 teeth. Late big twins 25 teeth. Sportster 35 teeth. V-Rod 64 teeth.
Rear Primary teeth At your clutch basket. Early big twins 37 teeth. Late big twins 36 teeth. Sportster 56 teeth. V-Rod 117 teeth.
First Gear :1 Ratio to One. Early 4 speed: 3.044; Big twin 96 up: 3.21; big twin 80-95: 3.24; Sportster: 4.30; Six-Speed 2.94 or 3.21 depending on make; V-Rod 2.51
Second Gear :1 Ratio to One. Early 4 speed 1.820; Big twin 96 up: 2.21; big twin 80-95: 2.31; Sportster: 3.15; Six Speed: 2.08 depending on make; V-Rod 1.68
Third Gear :1 Ratio to One. Early 4 speed: 1.227; Big twin 96 up: 1.57; big twin 80-95: 1.6; Sportster: 2.29; Six Speed: 1.53; V-Rod 1.34
Fourth Gear :1 Ratio to One. Early 4 speed 1.000; Big twin 80 up: 1.23; Sportster: 1.88; Six Speed: 1.24; V-Rod 1.16
Fifth Gear :1 Ratio to One. All models: 1; V-Rod 1.04
Sixth Gear :1 Ratio to One: .86 or .89; Enter 1 if no sixth gear.
Jack Shaft In teeth 1 if no jackshaft. Teeth on transmission output shaft if jackshaft is used.
Jack Shaft Out teeth 1 if no jackshaft. Teeth on jackshaft if jackshaft is used.
Trans Pulley teeth Typical big twin 32; 883 Sportster: 27; 1200 Sportster: 29; V-Rod 28 (Euro 30)
Rear Wheel Pulley teeth Typical big twin: 70; 1998 Softail: 65; Big Twin Export Models 61 or 65; Sportster: 61; V-Rod 72
Rear Tire Diameter inches 16" Street Tire: 25.75 (average); Drag Race Goodyear 29 or 31; 15" x 4.5" Goodyear Bonneville Tire (24.8; 25.4; 27.
Tire Growth :1 1 for street tires. 1.1, 1.15, 1.2 etc. for drag race slicks that expand with rpm.
24t front 30t rear"No PULLIES" and it came out 610mph in 5th WTF?
I'm not very good with number if I could gbet a little Help?
