Hello fellow land speeders,
I've got a rule question that I may ultimately have to officially pose to SCTA. However, thought I would ask it here first in the hopes that someone might have a definative answer, such that I could avoid disturbing the officials.
I am building a new blower motor for a modified car. I purchased a used blower set up that came complete with the hat. The hat has 4 ea. round 4" dia. butterflies. The area of these 4 butterflies = 4X4pi = 50.265 in2. However, when you subtract out the area covered by the bar which the butterflies are mounted to, then the total area is less than 48 in2.
Rule 4.B states that Air Intakes: "Protruding air intakes, other than O.E.M. must not exceed 48 square inches of frontal area."
Now my question is does this mean the area where the air actual flows into the hat? i.e. the actual surfact area into which the air flows? Because if it means the area of the entire face of the hat, then I have a problem. The total area is probably more like 60 in2.
Thanks for your consideration.
