I'm still waiting for the new rulebook or I'd just look it up, but I'm sure the top chop rules are not the same for gas and altered coupes, and competition coupes. Can someone clarify this?
Here is what I think I know (from 2006 rules), but it might not be right, so take it with a grain of salt.
4.I Chopping -- The removal of metal from a body component in such a fashion as to
reduce the overall height of the component
without changing the original shape at top or bottom.
4.K Contour -- Contour is........................contour. In the special case of chopped tops, contour is considered to have been preserved as long as the
angular relationship of the top to the body proper is not changed. page 57 Vehicles competing in the Competition Coupe and Modified Sports classes must
have documentation showing the stock vehicle BEFORE modification. (I don?t know
how many of us have that, but probably a good idea in case Dan and the guys don?t know what the vehicle looked like stock, Sum)
5.D.1 -- Comp coupes -- Other than chopping, no modification to the body is allowed
(cowl back I would assume). Minimum vertical windshield height is 5? (I assume this is
the actually glass area). The front and rear chop shall be equal. Window openings may be covered by flat plates on the outside of the opening or left open. .......then there is more not related to the top.....except this. Driver exit hatches in the roof are recommended, but shall not change the contour of the body (I would assume the top of the roof).
5.D.2 Altered Coupe (I?ll skip a bunch here as 49 and up bodies can not be chopped) Pre -49 bodies may be chopped. The chop shall be equal front to rear and must retain a vertical windshield height of at least 6? above the top of the cowl........ (so now we are not talking about the windshield?s height as above if I?m reading this right, but the height to the top of the glass above the cowl, a different animal...and continuing with the rule)......with a maximum horizontal length of 7? from the base of the windshield at the center of the car. (the way I read this is that the windshield itself can be 5 inches in vertical height with the top of that 5 inches at least 6 inches above the cowl. And in that 5 inch height it can be layed back so that the top is 7 inches back from the vertical at the top of the 5 inch windshield at the ?center of the car?. Note I?m getting the 5 inches from 5.D.1 above. So in 5.D.1. there was no mention of the angle of the windshield, but here it is added. Does it also apply to the comp coupe car???)
5.D.4 Modified Sports -- (down in the 2nd paragraph one sentence) Coupe Tops may be chopped. (my guess is you follow rules 5.D.1 and/or 5.D.2.)
From the above I made a drawing for a friend and said I think this is what you can do:
This also shows what I think is legal with the spoiler and spill plates.
So Dan if you have time is the drawing above correct for Comp coupe, Pre-49 Altered Coupe and Modified Sports Coupes??? Or are they different???
And the last question and this is pretty big. Can the top be chopped above the windshield like where the arrow is above if it doesn't change the contour of the top of the top?
I've seen a couple cars that have been cut in that area and then the top has been perfectly flat, almost directly above the glass.
