At Speed Week I was talking to one of the streamliner guys and he said that with the long lines it was very hard for them to run as it took a lot of prep up near the start to run.
[/quote]
I don't understand this statement? Does it take less time if the lines are short to prep the car at the starting line?
[/quote]
If you have run a streamliner, may be you would understand this comment. What this guy likes to say, was:
To run a streamliner needs some prep process - if you be in line you move the car forward, make this prep, move forward, next prep. Due to this that this streamliners is more like a closed rocket, panels has to be off for the prep, what means that the car and parts had to be moved all the time.
When a streamliner could stand on the side of the moving line of roadster, lakester and motorcycle all the job could be done without interruption from the moving, which would be a great advantage. Less stress means less possible mistakes which would be good for the safety, too.
I can understand this guy and I agree with this guy.
