About turn around...
yes, 2 hours for FIM and 1 hour for FIA......up to 1935 the FIA (now) had only 30 minutes...they changed it to 1 hour during the attempts of Malcolm Campbell at Bonneivlle, when he run at the salt instead on sand at Daytona Beach the tire had to be changed after every run...so the FIa done a quick reaction on the situation and stayed with it.
Tom Burkland had a hard time to stay inside the 1 hour rule when he run at the Shootout and start a talk with the FIA to change it to 2 hours....without a result....
The FIA has to understand that just for the safety it is necessary with the today more complexed racer to give the teams more time....
unfortunately the FIA is here very slow to make changes....how long it needs to get off the 1 percent rule....how long it needs that the wheel driven racers got the title as World Record back....
The FIA tries to protect himself with the comment....this wouldn't be fair to the teams which set the records before under the 1 hour rule.....in other words....they found an argument to do nothing
...instead of that they changing the records classes in 2014 from 11 displacements to 13....and also the numbers on weight classes for electric and turbine....
with the result, that to today the displacements 9-12 are missing in the FIA record list as they still couldn't find the correct record holder due to missing papers about the engine sizes....
next year we have the 10th anniversary for that change....
it's on all serious racer who likes to go FIA to go on the FIA for a change - of fairness between FIM and FIA - and of, much more important, safety in record breaking....
go together with Tom Burkland and support him and he will support you
