In the altered class you are allowed up to a 25 percent engine set back I've got the carb right under the cowl area at the bottom of the windshield. In fact the Lexon windshield will need to be notched for clearance above the carb. It's almost like people avoid setting the engine back even in Comp Coupe in order to avoid the problem. I've looked for pictures of cars that have addressed this but haven't found any. I will need to have my rear facing scoop go through my windshield to make this work. It is the altered class that allows the cowl to be extended and the use of fiberglass front ends. I just need to address this in a proper manner.
Thanks George
