build your bike with a roll cage
Jack! How does any of the devices listed limit the movement of the torso. They are all attacked or rely on the same shoulder harness and lap belts for support we now use. Sooooooooo to me it makes no difference which one you use because right now we are only discussing
forward head movement. The Hans device would be of no use I can see if it were not for the shoulder belts. The Hutchens at least attaches to you body but still relys on the shoulder harness to work.
If your going to respond to forward torso movement, which is really chest forward movement, The only thing to do is add another 3" "lap type" belt across your chest attached back to the cage...maybe 6 or 7"
I think I can fix all of this:
1.Radio controlled car with no driver w/tc
2. Design/Build car with known drag coefficient. Build motor with dyno sheet showing horsepower
Send in both for record Cert and Red or Blue hat if applicable.
Works for me
