On body modifications ( GR class )
If use a 29 roadster, can one remove firewall section infront of window ?
I seen pictures when a new hood is made ( slimmer and start at front window of body )
But I saw on Larry Erickson D/GR roadster he still had the cowld section under the new made hood.
I found this for the GR body on the Australian rules ( guess its the same as the US )
One more question ; I read that a belly pan is not allowed in GR class, in what roadster class is that allowed in ?
5.B.2 Fuel-Gas Roadster - /BFR, /FR, /BGR, /GR
The body at the original windshield line may be re-contoured to a flatter configuration, so long as the body contour is not lower than the top of the doors and the distance between the bottom of the frame and body contour, measured at the original windshield line, is not less than 71.76 cm (28-1/4 in.). Flat panels may cover grille openings. Door hinges, windshield posts, filler caps, and brackets may be removed. The configuration of the bodywork between the original windshield line and the grille shell is optional, as long as the overall length of the car, from the front of the grille shell to the rear of the body, with any grille shell, is no greater than 363.22 cm (143 in.)
