Everything you do to go fast costs HP.... including going fast.... some differentials are more efficient than others.... some transmissions are more efficient than others.... some overdrives.... well you get the point... Aero is the same situation... all you can do is optimize everything within the rules and compromise on the things you have to.... do all you can in preparation and bring all the HP you can afford... go to Bonneville and see if it works....
That is what LSR is.... your idea, your plan, your execution, your race and hopefully your record.
Not everyone gets it...
The attempt and first pass down the salt should be your initial goal... many that start the quest never get that far
After that you work your way up in speed till you get to go as fast as you can... with your idea, that you built and raced... sure everyone wants a record, a small percentage get one
Even when you get the record... you will want to go faster
