I have an idea for a rear axle that I wanted to post here and see if anyone had feedback on. It's somewhat similar to some designs I have seen, so I'm curious if anyone has experience and constructive feedback based on experience.
I have two axles I can have cut down to 8" long and re-splined up to the bearing landing. I can slide these into an internally splined steel sleeve that is split open along one side. I'll then clamp an aluminum sleeve around the steel sleeve to clamp down onto the splines. The steel sleeve and the aluminum sleeve will be connected with a machine key. I can then bolt the sprocket onto one side of the aluminum sleeve and the brake disc onto the other side. Four bearings, two on each side, will be pressed onto the bearing landings. I'll also have two bolts, one on each side, going all the way through the sleeves and the axles as an added security.
I'll have a swingarm that grabs the bearings and attaches the whole thing to the frame. The swingarm will rotate up and down, but both sides will be connected so if one wheel goes up, the other one does as well.
This is certainly way overbuilt for my ~100 horsepower engine, but it seems secure and I have all the tools to make it. I'm also trying to build in future capability to this streamliner in case I want to switch to a faster class in the future.
Let me know your thoughts.
