No build thread. In lower gears will pull to 91-9200 but falls off pretty rapidly there. Engine builder said should make 450. We had a two cylinder mule engine with my pipes, carbs, cylinders etc that made 183 on his dyno (I'm not sure it has ever been calibrated but his engines are top of the heap in their classes) so neighbor hood of 91hp/cyl. Pretty flat 85-8900 and then starts to fall off. Took some doing to attach to an automotive trans, work out clutch, shield, starter, adapter plate, you name it, not to mention fitting the pipes.
I'll attach couple pictures, may take several posts with the file size limitation.
