take on using lower roll cage tubing for engine coolant heat exchanger lines on a streamliner . front engine , tubes run continuous from front to back one on each side ,with a fanned radiator mounted in rear . using an electric pump to circulate .for engine water tank heat exchanger fluid only , not engine fluid . should have no to little if any pressure build up . can see the pros , great heat sink, less lines to run . cons , im inside the heat sink , inside corrosion , hassle to drain and a way to keep corrosion away . just a thought , if anyone has or done this
