Author Topic: 4 stroke vs. 2 stroke  (Read 2925 times)
Offline Jack Gifford
« on: August 16, 2021, 11:54:48 PM »
Speaking only about special-construction classes- am i missing something in the SCTA rules that differentiates 2-strokes from 4-strokes? For instance, could a 3 liter 2-stroke engine run in an F class car?
M/T Pontiac hemi guru
Offline trimmers
  • Jeff in Boise
Re: 4 stroke vs. 2 stroke
« Reply #1 on: August 17, 2021, 05:14:41 AM »
No, you're not missing anything.  Nothing in the rules differentiates between 2-stroke and 4-stroke engines,  Yes, a 3-liter 2-stroke would run in class "F".
Catzilla 2 ran at Speedweek this year as a G/FS, powered by two separate 1000-CC Arctic Cat 2-stroke engines.
Jeff in Boise
------------- 1 of just 3 in all 3  -------------
USFRA 130 MPH Club 09/18/2008 136.757
USFRA 150 MPH Club 09/17/2009 152.162
Bonneville 200 MPH Club 09/15/2019 218.600
Best Run: 253.080 MPH 09/14/2019 #6556
Offline jacksoni
« Reply #2 on: August 17, 2021, 07:49:02 AM »
Rulebook 2.A Engines: " Any internal combustion engine using either a two-stroke or four- stroke Otto cycle.......May run in any category except Vintage... See 2.A.1
Only streamliners and unlimited diesel trucks may use more than one engine.
Jack Iliff
 G/BGS-250.235 1987
 G/GC- 193.550 2021
 G/GMS-182.144 2019
« Reply #3 on: August 17, 2021, 09:26:22 AM »
Tom Donney runs two-stroke SAAB motors in MGT.
« Reply #4 on: August 17, 2021, 10:17:33 AM »
ECTA rules did differentiate between 4-stroke and 2 -stroke when I ran there in Maxton.  I don't have a current rulebook for them.  As I recall they ran in different classes (vs. same class with a break to one or the other).
« Reply #5 on: August 17, 2021, 11:03:32 AM »
But was that a motorcycle rule?
« Reply #6 on: August 17, 2021, 11:46:54 AM »
Well, yes, now that you mention it.  I wonder if there was something about 2- and 4-strokes for cars. . .
Offline jacksoni
« Reply #7 on: August 17, 2021, 11:52:12 AM »
last ECTA book I have is 2014 so not sure now, but they have generally followed SCTA rules pretty closely and do in this case (in 2014).
Jack Iliff
 G/BGS-250.235 1987
 G/GC- 193.550 2021
 G/GMS-182.144 2019
« Reply #8 on: August 18, 2021, 12:14:00 AM »
Thanks for the info. I'm surprised that two-strokes aren't exploited more in N/A land speed racing.
Offline jacksoni
« Reply #9 on: August 18, 2021, 07:52:59 AM »
There are a couple  :wink:
Jack Iliff
 G/BGS-250.235 1987
 G/GC- 193.550 2021
 G/GMS-182.144 2019
Offline panic
    • My tech papers
« Reply #10 on: August 18, 2021, 09:08:57 AM »
If you go back far enough, 2 strokes were given a displacement advantage in NHRA.
« Reply #11 on: August 18, 2021, 11:33:16 AM »
And now (if I'm not mistaken) NHRA gives Harleys a huge displacement advantage to keep their kind winning the Pro Stock (Harley) events.
. . . and then there are Pro Stock Mustangs with Chevy engines in them.
Offline trimmers
  • Jeff in Boise
« Reply #12 on: August 18, 2021, 03:58:34 PM »
Harleys?  What's that?  All I've heard them called this year is "V-Twins".  I suspect H-D pulled the sponsorship plug, so now they won't say their name, even though that's what they're running!   Of course, the Suzuki's are competitive, though.
Jeff in Boise
« Reply #13 on: August 18, 2021, 06:11:10 PM »
"Of course, the Suzuki's are competitive, though." . . . hauling a lot more weight per cu. in.
« Reply #14 on: August 20, 2021, 02:29:58 PM »
I love two strokes and Jack's engine is a real jewel! The amount of thought and engineering that went into it is staggering and it is a record holder now. His previous engine was a 4 cylinder (I don't remember the make) that he adapted an Indy 4 valve, DOHC head to, also an impressive effort.
If you want to see the ultimate two stroke it was the Crecy built by Rolls Royce in the late 40s. It was a 1700+ cu. inch V12, two stroke with rotary sleeve valves and made about 50% more power than the Merlin or Griffon 4 strokes. It was so loud that the first time it was run on a dyno it cracked the dyno cell walls!! Look it up on YouTube.
